47RE parts
47RE parts
Hey guys, I have a third gen with a 47RE and i want to beef it up with either Goerend parts or Suncoast. The problem is though, i don't know what parts to get other than a valve body. I plan to get a smarty and i don't think the stock tranny can handle it. I posted this question on the third gen page but know one answered so i thought i'd put it on here since the 47RE is mostly used on the second gen. trucks. thanks guys
If it's in good condition now, a valve body and new converter will make a big difference. Goerend is a good man to deal with. What are your plans and goals for the truck hp wise and daily uses.
Brett
Brett
3rd gen is 48RE (prolly why you got no response on a 47RE in the 3rd gen forum) - you got the good stuff already - if the trans is hi-mileage, you should opt for a rebuild - check over at PATC for more info and options - plus, you need to create a sig, so members will know how to help you.
Wanna know how that works? Your sig may list a '04.5 2500 and some goodies, plus the 47RE - first question will be "what are you doing with a 47RE in a 3rd gen - are you sure it's a 47, not a 48?". Etc..............
Word up, dude........
It has a 47RE because it is a standard output. I bought the truck used and it has an intake and a four inch exhaust. The paperwork shows that the trans was replaced already which tells me that the 47RE may be marginal for the engine. I found somewhere that the input torque rating on the 47RE is 450 foot-pounds which scares me cause the engine torque output is 460 foot-pounds. My plans are to add a smarty with a Fass lift pump.
CTD_Neil
07-19-2005 08:13 PM
