47RE help
Old 02-05-2007 | 05:14 PM
inline6power's Avatar
47RE help
was just given a BRAND NEW 47RE out of an 03 truck, only has 12k miles on it. my question is will it bolt up to my 99? i no a 47re is a 47re but not sure if all the connections are the same from 99 to 03.
Old 02-05-2007 | 05:44 PM
dzlfarmboy's Avatar
Dont the 03's have a 48re transmission?
Old 02-05-2007 | 06:36 PM
03 were half and half. some had the 47 and some had the 48.
Old 02-05-2007 | 07:25 PM
BigBlue's Avatar
I would think they would be cause I doubt dodge would redesign a transmission that they were getting ready to get rid of.
Old 02-05-2007 | 07:55 PM
badme's Avatar
47re or 48re it still should work
Old 02-05-2007 | 08:03 PM
JD730's Avatar
IIRC there's a change right around 99 or 00 involving the valve body sensor/transducer and maybe the connector. If you have any problems the proper valve body should make it work properly.
Try calling some of the trans guys and see what they say, one of them should be able to give you an answer.
Old 02-06-2007 | 01:20 PM
yup the case is different. the neutral saftey switch is completly diff from the 2 so if i was to ever use this tranny for MY truck, only thing i would be able to do is steal the internals
Old 02-06-2007 | 03:06 PM
zulusafari's Avatar
Talking
I would be more than happy to test whether or not it will fit! Just ship it to me here at..... I am sure I could find a way to add the necessary wiring and connectors...
Old 02-06-2007 | 03:32 PM
ha ha it would work if i wanted it to. i would have to use my 99 valve body as the connection there is diff , and do a little wiring and wamo. i might consider a sell!!!!!!!!!
Old 02-07-2007 | 10:14 AM
zulusafari's Avatar
Sounds tempting, but
I
am in the middle of a drwn-out relocation and pretty much flat broke. I am hoping to save enough for some of Dave Goerends magic parts when I rebuild my 47RE. I need to replave my VP44 first. Sigh. Always something!
Old 02-08-2007 | 01:34 AM
Mariner 250's Avatar
Inline, How much? PM me, thanks.
thehemikid
02-25-2021 01:45 PM
TomCs
08-23-2007 11:34 PM
Munchies
10-19-2006 07:09 AM
RAM123
13
09-15-2006 09:12 AM
dddrott
09-30-2003 10:17 AM
