400hp
400hp
Hey everyone, Found the truck and its a 24 v 99 4x4, most that doesnt matter for the question though haha, As the subject said im wanting around 400hp, and as much torque i can get. And from what i understand the fuel systems that just pump more fuel into the engine isnt good on them so i was wondering if someone could give me a good setup, Moneys kinda a factor yet not really haha. Id like to stay under 5000 So what do you all suggest? any info is appreciated<br>Thanks<br>Nate
Re:400hp
This is the order I would follow:
Gauges (EGT, Boost and Fuel Pressure)
DTT Transmission or South Bend clutch (you didn't mention which transmission you have)
Upgraded fuel lines and a pusher pump
PE Comp
4" exhaust
BDII's or DDII's
and you might want to check your turbo housing, 12cm minimum, 14cm would be better and a PDR35 or PDR40 would be great!
That should get you a strong 400+ hp and 800+ torque. ;D
PE Comp
4" exhaust
BDII's or DDII's
