4000 RPMs
Just be sure to do 3 good heat cycles on your springs before a test drive, then recheck valvelash & hammer down. Only thing you may want to consider is a coolant bypass kit, Enterprise Engines sells a nice kit for $150. A Flluidamper is another good idea.
When you turn higher rpms, your pressure in the coolant system rises & can pop the freeze plug out of the back of the block [most common]. The bypass kit has a pressure relief valve which opens when you reach a set pressure & reroutes the coolant back to the upper radiator hose. Some guys even clip/trim the blades on their water pump so that it doesn't build as much pressure.
You have to call enterprise engines [EEP] & talk to them directly, not listed on the website. www.enterpriseengine.com
jschintgen
01-01-2010 12:17 AM
5.9Excursion
04-29-2008 02:19 PM
AnythingDiesel
16
10-14-2007 11:34 PM
Bob Wagner
28
09-30-2007 04:16 PM
Bob Wagner
28
09-26-2007 08:26 PM
