400-450hp in a 24v
400-450hp in a 24v
My truck is a 98.5 24v.
I would like to sit around 400-450 rear wheel horsepower.
Right now I have RV275 injectors, Smarty, and a TST1 box. That gave me 275hp, 600ft/lbs torque.
I don't know a whole lot about diesel hop ups, so this is why I'm asking you guys. I don't want to buy something only to find out it's junk, when 10 people could have told me this if I asked!
I was thinking...
Keep the Smarty
add
Mach 2 injectors
TST 3
and a different turbo... HX35/40 or maybe HTT 62-14???
Any advice?
I tow and daily drive, so it has to be ok EGT wise. I have gauges and all, but I don't want to be feather footing it all the time cause I have a trailer.
I was thinking...
Keep the Smarty
add
Mach 2 injectors
TST 3
Any advice?
auto or stick? an auto will need some serious beefing and a stick will need a good clutch.
look up Bob Wagner, he ran 400hp with Mach4 sticks and a hybrid 35/40 turbo along with his Smarty.
i have HUGE respect for HTT. give them a shout for their suggested parts and tuning.
Trans is already built to hold it. Billet convertor, Billet input,... upgraded planetaries to 48RE stuff... more clutches where I could put them, good shift kit, etc.
I didn't figure would need Mach 4 injectors... I was thinking that is what the sled pulling guys are running.
Mach 4s would be ok towing still?? How is the fuel mileage??
Hohn, DZ = 35/40 hybrid???
I loved my Mach 4's.
24 MPG empty and I could tow as much as I liked. Of course, the right foot factor was critical.
I could not tow with the Smarty on any level. Edge stuff tows nice.
Dave
Dave
The setup in my signature with a edge comp instead of the adrenaline netted me 438hp. You wont need the twins a good single will work fine. i just had to see if I could build twins is all. When I dynoed I ran the Smarty on Sw2. It is addictive after you get to the 400-450 range you will want to go to the 500-550 range. Good luck with your project.
Joe
Joe
Ok, so how does Smarty, TST3, Mach 3s and a 62-14 sound??
I liked the idea of the HX35/40 for the cost, but if it ain't big enough, so be it.
Right now I am just planning, since I don't have the $$$. I wish I did, but I just dropped $600 to fly to Maine for Christmas and about $700 on the dog
Also anyone have info on the TST CE? They mention it on the webpage, but don't go into much detail.
I have been reading some posts and see alot about the drag comp.
It's about $200 more than the TST3, seems to be the same power #s.
Which is better?
I see the drag comp adds timing, so I'd have to run Smarty #8 I suppose.
Which is better?
