4 gauge setups???
4 gauge setups???
i was wondering if any of you have pics of your 4 gauge setup? i was looking at a 4 gauge pod that mounts on the dash above the steering wheel but i am open to suggestions. Thanks!
callum
callum
Top's Younger Twin
Not sure if you are referring to the Rod Pod I designed, however, its something you can use for any combination of up to 4 gauges and/or switches.
Theres pix of the Rod Pod at www.wildcatdiesel.com
Scotty
Scotty
"i was wondering if any of you have pics of your 4 gauge setup?"
Done.
This is a Rod's Pod from www.wildcatdiesel.com. I'm only using 3 guage holes for guages. The second slot are planned for buttons. Pardon the air compressor guage - I've been informed that it's 100psi ISSPRO replacement still in shipment from Canada.
brandon.
Done.
brandon.
I have 3 on the pillar and the 4th over beside the stereo.
http://www.directcon.net/drkayak/Ram/Gauge%20all.jpg
http://www.directcon.net/drkayak/Ram...20Pressure.jpg
i just got done this last weekend doing my 4 gauges i have the 3 on the pillar and the one on the steering colum it looks real nice i dont have a digital camera otherwise i would post pics. the only problem is that it covers the wait to start light and the e-brake light other thatn that i love it! got all my stuff from rob at wildcat
WOW! dr. kayak that is an impressive setup. i really like the pre-post on the FP and pan-line on the tranny, good idea. I assume you would need two senders for each. do you mind explaining how you did that.
For the fuel pressure I ordered 2 sensors with the gauge. Used the taped banjo bolts with grease gun hoses to help isolate the sensors from the injection pump. A lot of people have had problems with sensors failing when they are placed post fuel filter. Mine has been in for over 2 years with no problems. You can see a normal 2-4 psi difference between the pre and post filter reading.
Looks like several good ideas here. I am leaning towards Firestorm's 4 guage adaptation for the A Pillar, but I like Phox's setup with the pyro next to the pillar on the dash, too. Dr. Kayak has a sweet setup also, but I really like how well my cell phone fits in the cubby hole I suppose I could always get an external holder.
I saw on a sight where a Ford van owner added two 2-guage pods together on the a pillar for four guages. It looked pretty good, too, but I don't know which is best. I liked the looks of the three guage full pillar with a single guage added.
Firstgenfanatic
06-06-2011 05:25 AM
