4 or 5 inch straightpipe exhaust on a lightly modded 215 hp 12 valve?
Old 05-01-2008 | 03:21 PM
Bookshelf's Avatar
Which exhaust will give the best performance on a 96 5 sp 215 hp CC 4x4, a straight pipe 4" or 5" system? It'll probably have a 10 plate, GSK, BHAF, and a 62/12, so the turbo will have a 4" outlet. Which will give the best power, torque, spool up, and fuel mileage?
Old 05-01-2008 | 03:32 PM
olddodgetruck's Avatar
a 4'' is plenty rember the bigger you go the more drone you will have
Old 05-01-2008 | 04:05 PM
William12Valve's Avatar
I have had both and there was no noticable difference in power, milage, or any other performance aspect. There was a difference in sound like olddogetruck said there is alot more drone with the five inch. Sometimes i wish i still had the 4 inch. Very nice sound. Hope this helps.
Old 05-01-2008 | 05:57 PM
Lil Dog's Avatar
It has been reported in old posts that unless your turbo has a 5" outlet (IE compounds) you are best sticking with a 4" pipe. The 4" pipe flows better than the 5" for the HP and exhaust flow required. I remember reading some guys loosing HP on the dyno with 5" vs 4".. Too much pipe diameter causes the exhaust flow to become turbulent and doesn't flow as well.
Old 05-01-2008 | 06:03 PM
Bookshelf's Avatar
Thanks for the input guys, I've had 4" on firstgens before, but not 5". I was only thinking 5" because of the 4" outlet on the turbo. I can't find a 5" stainless system anyway, so 4" it probably is.
Old 05-01-2008 | 09:56 PM
smoky beast's Avatar
not to hijack, but would a 5" shorty exhaust straight piped into 6"x20" tip be absoluteley positively loudest exhaust possible? I don't mind drone
thanks
Old 05-01-2008 | 10:44 PM
aksparkey01's Avatar
I think my 4" was louder than the 5". but if you want noise go with a stack. just put my singer 7" grandrock on yeasterday and it sounds pretty good.
Old 05-01-2008 | 10:47 PM
mxyoest29's Avatar
go with 5 i love the drone cant wait till i put 5 in on this summer
Old 05-02-2008 | 09:30 AM
the drone is not bad with the stock turbo. once i put an aftermarket turbo on with a 4'' outlet. the drone got worse. then i put a set of 6'' stacks in and i had to wear earplugs on the highway because my ears would be ringing. once i put on the twins it totaly went away. to me the cost of the twins was worth it just to get rid of the drone.
Boatnik
02-12-2012 09:50 PM
p0wd3rp1l0t
08-09-2010 08:08 PM
Bsplyr500
06-06-2008 08:37 AM
Got Smoke?
16
07-02-2003 03:38 PM
21
12-03-2002 11:10 AM
