3rd gen coversion or lukes link
the 3rd gen kit is $$$ but its the best ive seen so far and well worth it. a fried of mine just put the thuren kit on his he says it drives as good as mine but i havent drove it yet. i know it is alot less $$$
When you say rebuild the steering, are you referring to the trackbar? On the track bar, a 3rd gen conversion or a thuren bar would be better than using a luke's link. However, if your problem is tie rod ends, the luke's links would be a good solution.
I have the 3rd gen & highly recommend it, although my brother has the Lukes Link. It really impressed me how tight the steering has been for a year now, still no play in the link. I think that both are great upgrades.
I had the Luke's Links on my 2nd gen track bar and was quite happy. I now have the 3rd gen setup which is a permanent fix for the poor factory design. Many people will disagree with what I am about to say but I would not do the Thuren replacement. That design has the ability to do what the factory design does, the only difference is you get a mono ball instead of a tie rod end, it will still allow side to side movement. Eric
Shelljerk47
22
05-05-2007 07:04 AM
