370 injectors part#
370 injectors part#
ok guys here is the deal a couple of years ago i picked up some new injectors and never got around to puting them in. well now i have finaly got the time to do it so here is the problem. i cant remember what size they are they are bosch part# 0 432 131 753. now i have found a few places that say they are 370's and a few that say they are 330's like dieselsmoke.com and some other places that i cant remember. so withch 1 is it?
also my truck is a 95 2500 5spd 4x4 with a high performance clutch strait pipe and the star wheel turnd up. so since my truck is basically stock am i going to have any truble running the injectors if they are 370's. i know i need gauges but would it be ok for a couple of weeks till i can get them. and also will the stock fuel system be ok for a wile till i can upgrade
thank for the help
thank for the help
Stock fuel system will be fine way longer than your stock turbo Guys are running twins on stock 12v fuel systems. It is really only the 24v that have issues with the fuel delivery.
Gauges before mods. Always. You have had the injectors sitting around for a couple of years, you should be able to wait a few more weeks till you can get the gauges.
And welcome to DTR, I just noticed this was your first post.
Gen 2- 100 hp Stage 3 370 Bosch Marine Injector #0 432 131 715...from what i can find it looks like you have the 330s, i also saw on dieselsmoke.com that they were the 330s. If you are still unsure try giving bosch a call? Good luck.
thanks for the info i know i am going to need to change the timing also. but i live in the middle of know where its like 90 miles to a any place that can do it. so will it run ok till i can get there?
diesel_man98
05-18-2008 05:08 PM
