330s in a 12v ?
330s in a 12v ?
I keep seeing people say the 370s will make my TC cringe with displeasure.
So.... how about the 330s? can i run them without causing any major damage?
Or what are my options?
I just need some more power, and some more smoke, that fogging the tailgaiters is addictive
if 215s shot your tranny, even in my limited knowledge, i think you may have had a problem already.
I only have some minor mods, more than 215s would provide i think, and on occasion ive been known to stnad on it in a brake torque for a good while
The tranny never gave me a bit of grief running an 8 plate and the 3K GSK. I swapped in the 10 and the injectors and noticed slippage immediately in 3rd lock-up. Hauling my camper and pulling a boat to the lake killed it.
But, it sounds like you have your heart set on getting the 330's. Go for it. No sweat off my......
I assume you mean the TC lockup clutch? Power braking is in fluid coupling mode and the clutch isn't in the mix.
With stock injectors, I toasted my TC lockup clutch with 3k GSK and a #4 plate fully back.
Not only did I destroy the clutch, but the hp level was beyond the hold capacity of the stock converter in fluid coupling.
The transmission itself was in great shape.
Russell_d
02-25-2007 10:12 AM
CTD2001
02-03-2007 02:30 PM
