315's BFG
Re:315's BFG
[quote author=shaft link=board=7;threadid=17385;start=0#162607 date=1058850880]<br>Do I need an alignment after upgrading to these 315/70/17 AT BFG? Thanks.<br>[/quote]<br><br>Most definately get an alignment after every new set of tires!
Re:315's BFG
[quote author=phox_mulder link=board=7;threadid=17385;start=0#162836 date=1058910783]<br>Especially when going bigger or smaller.<br><br>You've changed geometry of the front end.<br>phox<br>[/quote]<br><br>Not to start an argument but if the springs have not been changed, how has the geometry chaged? I can see getting an alignment to prevent wearing out new tires, but i've had 6-7 sets of tires between my two trucks (and on the ranger, going from a 24-25" tire to 31" so that's a definite size increase..) and have never noticed abnormal tire wear or pulling.
Re:315's BFG
Ok, now that I sit and think about it, maybe it doesn't change.<br><br>On a new truck you shouldn't need an alignment, but if it is a couple years old or older, get one.<br><br><br><br>phox
Re:315's BFG
Well, allignment does not change- all the angles remain the same. But if you change tires it may be adviseable to change the allignment to make better use of the different characteristics of the tire. eg reduced toe in for low profile tires that you mount to improve handling- this will lead to the truck having more tendency to oversteer, and will also lead to a better brake performance, but will sacrifice stability against lateral wind. <br><br>HTH<br><br>AlpineRAM
14
03-10-2003 10:52 AM
