315/75/16 Tires Will they fit my 2001
OK looking for some help. Want to put the 315/75/16 on my 2001 2500qcsb. My question is will a leveling kit be enough or do I need a 4 inch lift. I like the tire filling the wheel well look. Thanks for your help everyone.
I had that exact tire on 16x8 with about 4" backspace and a 2" coil spacer, got some minor rubbing, just irritating not damaging.
now have 35x12.5R17s on H2 rims with same suspension, NO rubbing at all. rims have about 5.5" backspaceing. Thats where its at I think.
1 Post
I've got 315s on mine with the Skyjacker D25 coils, stock wheels, and the only rub is on the control arms at full lock on the steering wheel. I've tried a little, but I've never been able to compress the suspension enough to make them rub anywhere else.
Muted User
with a leveling kit, 315's on stock 16x8's are as big as you can go without risking some severe rubbing. Depending on the tires you go with you'll get rubbing with the steering wheel fully turned, as mentioned, but that's about all. A lil' aesthetic scraping, but nothing to hurt the truck....
I should probably mention that if you buy through a tire store, they wil try (or at least they did with me, and I know when I worked at Big O, I was told to discourage it) to talk you into 305's, and claim that they "won't fit". Ignore the tire monkeys ;-)
thebestofindica
04-05-2007 10:31 PM
sakisaki400
23
12-31-2006 10:17 PM
