30psi good or bad
Old 02-10-2008, 03:44 PM
Jturs's Avatar
30psi good or bad
at max boost i am reading about 30psi with my stock charger is this to much for what i have got? all mods should be in sig....
Old 02-10-2008, 03:49 PM
bullboy85's Avatar
no stock turbo good for 35 psi. it can do more but your out of the map after 35.
Old 02-10-2008, 03:53 PM
lovinCTD59's Avatar
You will be OK. I can reach 33-34Lbs with my stocker... Just stay under 35, after that you it wont be efficent and will take life off of the charger.
Old 02-10-2008, 05:03 PM
Ph4tty's Avatar
Its perfect as is
Old 02-10-2008, 09:45 PM
JSPulliam21's Avatar
30 psi good! Hammer down and let 'er eat!
Old 02-11-2008, 06:28 PM
Jturs's Avatar
alright thanks for the input guys.
i just wasnt sure cause i dont see much opf a difference between lets say 25 psi and 30psi..... might be losing it in the tranny.
Old 02-11-2008, 07:43 PM
Valv's Avatar
That looks great, 30lbs is almost perfect. I will be perfect if you get rid of your K&N !!!! Get an AFE or at least a BHAF
Old 02-11-2008, 09:28 PM
Jturs's Avatar
whats wrong with the k&n? is there a AFE that the same size so i can still use my same intake tube and shield?
Old 02-12-2008, 01:58 AM
bullboy85's Avatar
K&Ns arent bad, but these trucks like dry filters, you risk alot by useing a oiled one.
Old 02-12-2008, 07:19 AM
aFe filters are designed for the diesel application, but they are still oiled. The high suction of a turbo sends to suck dirt and oil past the filter media. A good dry media filter like a paper BHAF or Amsoil 4510 would be a good choice.
Old 02-12-2008, 07:38 AM
Krob's Avatar
how do you get more boost from stock charger? I know it has something to do with the waste gate but how?? I know its kinda dumb question.
Old 02-12-2008, 09:00 AM
More fuel and an adjustable boost elbow. Auto trucks use a J-hook.
Old 02-12-2008, 09:49 AM
Krob's Avatar
Ok on y rig what would i have to do to get more boost?
Old 02-12-2008, 10:34 AM
Ph4tty's Avatar
You have to slow/ disable the wastegate. Either buy a j hook which is a spring what will help keep the wastegate closed to a point, or you can use a turnbuckle to hold it completely closed. Search for j hook and turnbuckle for multiple pics. Jhook is like $30 and a turnbuckle might be 5
Old 02-12-2008, 10:53 AM
I see you have a Quadzilla XZT+. Did it not come with a boost elbow? On your 6 speed truck you must use a boost elbow. Look at the bottom front of the turbo where the discharge tube is. You should see a rubber hose connected to a brass fitting. The brass fitting gets replaced by an adjustable boost elbow. The rubber line connects the wastegate actuator to boost pressure. It opens based on the amount of boost it sees. The adjustable boost elbow allows you to adjust how much boost the actuator sees, and keep the wastegate closed longer or completely. Actuator sees no boost, wastegate does not open, turbo builds more boost. Here is a link to a boost elbow at Vulcan Performance.
Quick Reply: 30psi good or bad
