3'' twins air charge pipe?
well, here is a new question im preparing the cold/air charge pipe for my 62/71/14/ ht3b twins, i know that ats and bd use 3'' intake charge piping, they are smaller turbos in comparison to my 3b, but i can put together a 3'' charge pipe for $42 but a 3.5 or 4 will cost at least $130+ will a 3'' charge pipe work as well as a 3.5? thoughts? TIA
Casey
Casey
I think the 3" would be better than the others. Discharge on 3B's are 3", no? And the inducer on your turbo is 62mm, which is about 2.5". Going bigger creates a bigger volume that must be compressed, and I can't see it helping with flow. That being said, I think the bigger pipes look better. But function over form.
The 3b has a 3 1/2 inlet. You could always put on a increase/reducer boot and use the 3in. I'm planning using 3in on my next set-up. My current set-up uses 4in. Its all trial by error for me, I always have to try things for myself.
TIA
Casey
3.25"
I made my coldpipe out of 2 3.5" U bends I paid $60 for both. Secondary inlet is 4" correct. IMO I wouldn't want to reduce the coldpipe coming right out of the primary it isn't much of a funnel but still a funnel.
