3 hp quadzilla?
3 hp quadzilla?
i put the quadzilla xzillaraider on about 2 months ago she works good smooth power. quad said it should put 120 hp to the ground he had seen it. well from my base line to level 2 it showed an added 64hp pretty good considering it says 70 hp. when we went to level 3 it showed 67 hp ????????? what gives? i always thought there wasnt much difference bettween 2 and 3 anyone else have these results ? do i have a bad box?
DTR's 'Go to Guy'
There may be things on your truck limiting its ability......clean fuel filter, good fuel pressure, clean air filter? Just saying there could be more to it than just the box. I can't see where it wouldn't work as well on one level than another unless there was something else limiting it.
fuel is fass 16 psi 15 wot , clean air , the connection is for all 3 stages it fuels it. supposed to be 30 70 120 like i said 2 works pretty good as far as i am concerned its just level 3 robbed 50hp
Mike, sounds like a pump wire thing to me too. I'd check your connection at your VP and/or make sure you tapped the right wire.
It happens all the time. Make sure you get the wire closest to the block. The module will still fuel like an EZ through the canbus and map connectors. You just don't take complete control of the VP until you tap the wire going to it.
well i will check again but i do believe i tapped the right wire she fuels hard on #2 setting you can feel when you turn the box on and off.
Same thing goes for an Edge Comp. Without the wire tapped, it has the same lower power as an Edge EZ.
IF you did tap the correct wire and have a solid connection, then there may be a problem with the box.
