3 gear launch
3 gear launch
Hey alright so dumb question what is a 3rd gear launch and how do you do it.
THanks sorry for the dumb question.
I did it with mine a few times until the stock clutch didn't like it anymore....
Now I need a new clutch, was going to need one anyways. I'm surprised it lasted that long with the extra power I have going to it, though.
Dual discs are the better ones to do that with. They will take the slipping better than a single disc. When I do it, bring it to 3000 rpm, and let out the clutch at a rate that won't bring the motor past 2500 rpm at full throttle. When I do it right, it works great. If I get off the clutch too quick, it will pull the engine down to 800 rpm or so and makes for a smokey show.
I have done many 3rds but 4th is a blast
Bring the ole tach up and then back down until its points straight down way past 4000 rpms then let her slip until you blow a drive shaft or the tires break loose for one heck of a smoke show going in all directionsMan I love my 12v
DM01.
DM01.
Ahh yes, glorious 3rd gear launches. They do this to really expensive clutches.
It still holds though . . .I'm not doing any more launches like that. I just don't ever want to buy a new one . . .
Oh, this is why I took the tranny out:
They are really fun, but the number of times you can do them are limited.
Take care,
Phill
Take care,
Phill
DTR question asker
Take care,
Phill
Take care,
Phill
That looks painful!
I wish I still had pictures of my tranny, that is nothing. My nearly stock powered truck ate the tranny at 70 MPH pulling a trailer. It would only grind when I let off and let the engine do a little braking so I drove about 80 miles after hearing/ feeling the initial bindups. Needless to say, my tranny rebuilder reused three gears and the case. Everything else was toast.
13ALPHA
17
04-28-2008 08:44 PM
pwrtripls1
03-03-2008 09:59 AM
matego
26
09-28-2007 02:09 PM
