2wd low kit?
Originally Posted by whitebuffalo
Ad removed site violation
Originally Posted by Tiger Rag
Did a search and can't seem to find any threads on this. Just looking for the best place to order the kit.
Thanks in advance, Matt
Since ur truck is a 4wd,
Posi lock it and forget it, and you will have a two low option (just dont engage the front axle) and you will have a reliable 4wd, for what it costs, you cannot go wrong.. You can get the kit from 4wheelparts.
Rick
Rick
Rick
a posilock is a cable actuator for you CAD that uses...well....a cable instead of the vacuum lines provided stock. they run around 200 bucks. i made one for my jeep for ~$25, but its not as heavy duty or clean as a true "posi-lock"
and...not being a jerk or picking a fight, but im not selling a home-made posi-lock so please dont delete my post
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
Purchased a solenoid, 2G497 from Grainger. This is a very small 12v solenoid that is used with a lot of the exhaust brakes. You also need a switch, two 1/8" barbed hose connectors and a bit of wire, ten more dollars.
To install find the vacuum line along the top of the firewall just above the fuel filter. This is the vacuum line going down to the transfer case. All you have to do is place the solenoid anywhere in this line, which when switched on will block the vacuum from going to the stock solenoid that is activated when you pull the transfer case shifter into 4wd.
Simple as can be.
BD also makes an excellent kit for $85.
1-800-887-5030
Simple as can be.
1-800-887-5030
Phil, thanks for the suggestion. May have to talk to you about it soon. Sounds simple enough though. Hey you coming to East Bend for the pull tomorrow night? Mike D, Brian B and I are probably going. Got a spare bedroom if you want to crash here and a beer fridge in the garage!
Peter, thank you as well. Good speaking with you earlier this week while ordering the 3600 DD clutch and hydraulics. Look forward to its arrival Monday with an install to follow the next weekend.....
Your suggestion on backing with the DD has me seeking this. Sounds like a no brainer.
Thanks again, Matt
![Cool](https://www.dieseltruckresource.com/forums/images/smilies/cool.gif)
Thanks again, Matt
No problem, I didn't make it, I tore my back up really bad. Out of work today, can't even get dressed or put on my shoes. The doc gave me some good drugs
. Which clutch did you get? I am assuming Tim is gonna put it in? Did you get any credit for the other one? What do you think about Mikey breaking the Opie output?????
Cheers!!
![Crazy!](https://www.dieseltruckresource.com/forums/images/smilies/crazy.gif)
Cheers!!
Cheers!!
Cheers!!
![guitarist](https://www.dieseltruckresource.com/forums/images/smilies/guitarist.gif)
Hate you messed your back up.....that is no fun at all......well except for the good drugs and all..... The OFE is fine so I may just hang onto it. I may sell it as it is in good shape with only 5-6000 miles and only 6 months old. I just want to see how this one performs for now, then I'll make a decision toward it.
Me thinks Mikey has more power than the dyno says. I think the Smarty doesn't let the max power be read properly on the dyno. Tim thinks about 50 hp in some trucks. Still though....breaking a billet shaft?
I just don't think you and I want to do that thing without a lift Phil....it is a beast (390#'s dry I just read the other day).
I agree with you on that one!!
Resurection of an old thread!!!!
Simple as can be.
1-800-887-5030
Simple as can be.
1-800-887-5030
Jordan5687
02-18-2009 02:48 PM
Bobcat698
04-01-2007 10:26 PM
