2nd gen willy whistler
#31
Well I hooked up my Amsoil racing filter and took it for a spin yesterday and can't say as I noticed any difference over the BHAF other than 1psi lower boost at cruising speed. The whistle seemed the same as well as the power.
#32
That set up is for the save a penny kinda man,
works just as good as a filter system but is a hell of alot cheeper.
Good work man, little bit of afro engenering keeps one young
and Sawyer1 you could have saved on 5 doller diesel by going to lowes that was specified earlier in the fourm.
#33
oh and kenin sorry for the total thread hijack
#34
#35
can someone give a diffinitive answer on the 6"-4" reducer?
all the a/c ones i've seen look like tin and have a seam that runs along the length of reducer ...
if it's solid i'll take one ...
#37
I will let you know the results.
#39
The reducer is a standard 6"-4" galvanized metal HVAC adapter. I plan on putting silver/metal tape along the seam and being careful when tightening it. Remember, this is supposed to be an inexpensive way to get A LOT of big air into your engine. It's either $70 for a BHAF with adapter or $250 for a big name one....
#40
or use this stuff called hard cast duct sealant but yeah you can use silver tape.. thats what i used in the inside of mine so its all sealed up. then i painted it flat black. it looks really nice EXCEPT I LOST THE DARN CLAMP FOR THE INTAKE TUBE. i had it laying in the seat of my truck and my grandpa got in it and i guess kicked it out of the truck. so i had to use a stainless clamp that i jacked off a big rig.
#41
I picked up the exhaust 6"-4" reducer today and I think it is going to work great. It is a lot stronger than the Hvac one so no fear of collapsing under hard tightening. I had them swedge the 4" end up to 41/4" to make a good fit on the elbow. I haven't installed it yet but I am sure it is going to work just great. It cost me $43.60. I will keep you updated.
#42
Finally got a chance to install the reducer. I welded a support bracket on it to mount it to the fender before putting on the filter and it works great. The filter is about 11/2" off the fender so it can draw air from all around. Took it for a run down the highway for a ways and it whistles real good and seems to run a bit lower on boost and EGT's. Next test will be with a 14,000lb trailer behind.
#44
It's just a galvanized steel A/C reducer. Go to Lowe's or HD and get in the "big galvanized pipe" aisle. Look for the reducer, it's pretty obvious as it's a common reducer. About $5.
#45
I have a question I got a 4 to 6" coupler felt the metal one was to weak but now I need a new hose since the OEM wont go into the the coupler where can i get5 one?!!??! locally MIAmi FL
