2nd gen willy whistler
Old 09-14-2008, 03:44 PM
Sawyer1's Avatar
So does this do anything to you're power? Is the filter actually allowing more air through or is it just the outlet size that makes the difference?
Is the filter an oil media type or dry?
Old 09-14-2008, 09:51 PM
Willy91's Avatar
This filter will flow quite a bit more than a BHAF. I noticed maybe a small egt difference at best.
Old 09-15-2008, 10:38 PM
Sawyer1's Avatar
I wonder if it filters as well as a BHAF?
Old 09-16-2008, 09:37 PM
Sawyer1's Avatar
Did I ask a stupid question?
I would like to use this setup on my daily driver which also pulls a 12,000 lb trailer a lot of the time and i would like to know if this will work or am I going to look at a engine rebuild in a yrs. time because of inadequate filtration.
Old 09-16-2008, 11:41 PM
wcbcruzer's Avatar
Filtration should be adequate since they advertise it for this engine. However, I personally would go with a dry filter, like BHAF or AEM. I don't like oiling air filters.
Old 09-17-2008, 07:11 PM
Willy91's Avatar
this afe is dry.
Old 09-17-2008, 08:14 PM
VWPAT's Avatar
You can cut a 4 inch hole there in the corner of the firewall and get some fresher cool air in there, and it sounds like a 747. I have mine cut with one of the old Scotty 2 systems.
Old 09-19-2008, 11:00 PM
Sawyer1's Avatar
Ok.One last silly question. You guys are saying to buy a 4-6 reducer at the hardware store. Just what kind of a reducer are you refering to. Is it ABS or metal or what? Got any pics?
Old 09-20-2008, 08:56 AM
Ph4tty's Avatar
I was about to mention the same thing. It didn't help spool or egts but it sure made the turbo sound louder =)
Old 09-21-2008, 10:54 PM
Sawyer1's Avatar
Thumbs up
Originally Posted by Willy91
or you could do what I did. Just get a 4" to 6" reducer from a harfware store, and just use the stock pipe. $12, whistles just dandy.
What store did you get the reducer at and whay was it's original purpose?
Old 09-22-2008, 10:06 PM
psd tuner's Avatar
ok i just ordered a amsoil part # EaAU6080. its a dry filter, ill let yall know how it turns out.
Old 09-24-2008, 09:01 PM
Sawyer1's Avatar
I hope yours turns out better than mine> I picked up my Amsoil 6080 filter and spent the better part of three hours running around the city to find a 6"-4" reducer. Finally found one at a plumping and heating place. Got home and went to put it together and lo and behold the intake elbow on my turbo is 4 1/4" not 4" like was posted so I guess its back to the drawing board.
So is the turbo inlet on the 24v's smaller than the 12v's or is everyone just clamping it down that far? I can clamp it tight on the 4" flange but just don't feel good about it.
Old 09-24-2008, 09:08 PM
Willy91's Avatar
clamp it down
Old 09-24-2008, 09:36 PM
Sawyer1's Avatar
clamp it down
Thanks. I will give it a try.
Old 09-24-2008, 09:55 PM
psd tuner's Avatar
i work as a hvacr tech. so the company that i work for had a 6-4 reducer sitting on the shelf. its ment for ac ducts it will work fine, i also painted it flat black. i did get my filter in today but hadnt had time to put it on!
Quick Reply: 2nd gen willy whistler
