2nd Gen....Smarty+XZT....?
I PM'd Quad, but haven't gotton a response yet, so I'll throw it out here.
I did a search on "XZT+Smarty" and got a lot of hits for 3rd Gen, but nothing for 2nd Gen.
I know how the Smarty and EZ combination is, but who has tried the Smarty and the XZT? The EZ+Smarty seemed to feel stronger than just the Smarty alone at higher RPM's. Are the results with the Smarty+XZT about the same....bettter....worse?
Why don't you try a fueling box instead? The smarty/ timing boxes can only add so much fuel and any one adds enough timing. Basically you'd just looking at different fueling/ timing maps stacking a smarty with a timing box.
Bottom line is you can spend $400 on the box and maybe see 5 hp or you could spend $500 on a Blue Chip apb and see maybe 85.
And the XZT is similar to the APB and the Xzillaraider is muc stronger.
The XZT is a pretty mild hp gain but, it is all controlled via the direct connection to the pump.
It is a lot different than an EZ.
We do have a competing product coming for the EZ but, this is not it.
The XZT will run off and leave an EZ from start to finish. At throttle it has a much larger torque curve than the EZ.
You are fairly limited on the Can Bus as to how much and how fast you can fuel.
Tap it, just don't leave it maxed out all the time =P I was seriously considering the apb at one point in time. I like the idea of just turning the dial for fuel whenever you want a little something extra
