2nd Gen Cab roof lights Harness?wiring?
Old 09-28-2008, 06:20 AM
smokinram99's Avatar
what type of wiring harness can I use to plug the cab lights? whre I can keep the source to lighten them? from overhead console maybe
let me see your install, I wanna install them with a on off switch in the OH console..
any suggestion will be much apprecciate
rob
Old 09-28-2008, 07:25 AM
97 D-Tec's Avatar
did your truck come with them? mine was factory so when i put my smoked ones in but i think recon lighting has install instructions for thier cab lights
Old 09-28-2008, 02:45 PM
my truck doesn't come with cab lights from the factory... I need a template? it comes with recon or oe set of lights...
rob
Old 09-28-2008, 07:41 PM
haloman's Avatar
The factory set comes with a template, the recon does not. I made my own wiring harness for the lights.
Old 09-28-2008, 08:22 PM
badme's Avatar
I bought the kit from the dealer for mine. It came with the template, harness, and directions.
Old 09-28-2008, 10:41 PM
97 D-Tec's Avatar
no i had to look farther.. recon has a pdf file but its measurements are for the 03
Old 10-05-2008, 11:00 AM
Big Deezul's Avatar
how much were they?
Old 10-05-2008, 09:59 PM
badme's Avatar
Originally Posted by Big Deezul
how much were they?
I don't remember, it was quiet a while ago.
Old 10-06-2008, 05:17 PM
Big Deezul's Avatar
got a guess?
Old 10-06-2008, 07:30 PM
badme's Avatar
got a guess?
Nope, but my wife works in parts at the Dodge dealer up the street. I will have her check it out.
Old 10-06-2008, 08:26 PM
Big Deezul's Avatar
thats very cool of you
Old 10-06-2008, 08:59 PM
98whitelightnin's Avatar
I ran my wire to the headlight switch. Just find a hot wire when the parking and headlights are on. If you pull your headliner down you should already have holes in your roof on the inside as it is a two piece desine. I got a 1 or 1and 1/8 inch holesaw and it fit perfectly in the holes,just drill from the inside out and you cant mess up. I also got all my lights and full harness from a wrecking yard for 50 bucks.
Old 10-07-2008, 08:36 PM
can17's Avatar
how much were they?
Mine were ~ $90.
Old 10-07-2008, 08:40 PM
klx650a2's Avatar
I made my own wiring harness and hard wired the lights in (re. soldered, splicing tape and liquid electrical tape).
Old 10-07-2008, 10:00 PM
arcticcat12224's Avatar
Its a simple series curcit Im in college right now at Suny Morrisville and that is what were learning in D-Tec Electrical.
Dont think it sould be that hard getting them to light up run a fusiable wire from the dash lights or something like that. I would find a template thought wouldent want to make them crooked or anything!
Quick Reply: 2nd Gen Cab roof lights Harness?wiring?
