2nd egt probe
2nd egt probe
I will be installing an attitude this weekend and would like to leave my existing gauge and pre turbo probe in place and also install the attitudes probe pre turbo for comparison.
Would there be a problem mounting the second probe just upstream of the existing or in the front three cylinders? The temps in the front three could not be that far off from the rear three, could they?
Thanks Mooseman
Thanks Mooseman
Originally Posted by Bart Timothy
No need for a second thermocouple. You should be able to run the attitude and exisiting pyrometer off the same thermocouple.
mooseman
Originally Posted by mooseman
I thought the same thing but was told that not all thermocouples are the same and may send wrong info to the attitude. Ill ask Edge for sure when I meet with them on Friday. That would defiantly be the best way to go if it will work correctly.mooseman
Originally Posted by Dr. Evil
If he has thermocouple 1 in his exhaust manifold/downpipe....how is he supposed to measure another temp without a second thermocouple??
As I understand it, he's not necessarily wanting to add another thermocouple if he doesn't need to. He wants to keep his current guage and use the attitude at the same time, unless he wants to measure the temps in 2 different locations.
whoops, I may have read the second post closer than the first.
Thanks Mooseman
