275 Injectors?
275 Injectors?
Hey guys will 275 Injectors help my low end like an EZ? or a good amount over stack I'm unsure weather to go with a box & Injectors, since I can get injectors around 270 & a box is close to 500 or more.<br><br>DRecu!
Re:275 Injectors?
I've installed the 275hp injectors about 2 months ago. Good improvement over stock. I also had a program put into my ecm.at the same time, so I can't tell you how much more by themselves. I ran a truck with just the inj. alone and he wasn't much of a match. Since then he had his ecm reprogramed. Ran him again and could only take him on top end. You might want to go with the box for now. But keep in mind to get one you can still use when you go with inj. This bombing is addictive. I'm looking into bigger inj. already.
Re:275 Injectors?
drecu<br>Right now I am running 275's alone. They are better than stock, but nothing to write home about. With my EZ, things were much better. Now I am waiting on a PowerMaxx3 to arrive ;D. If it were me, buy a box first, you'll be much happier
Re:275 Injectors?
I looked into it quite a bit myself and thought that I might get the bombing bug as well. I was looking at 275's first and I saw at one time alot of people going to bigger injectors a few months down the road. I went with DD2's and I will get a box when I upgrade my clutch. If you plan on bombing more get the 2's. The 2's helped the upper range from 1800 on. I dont know about the box because I dont have one right now. The 2's give you around 80 horse over stock or 90 if you have the six speed.
BigBlue
07-17-2003 12:56 PM
Chrisf
06-27-2003 07:27 AM
