24V, What Is The Best Gasket To Uas???
I cleaned mine with gasket solvent and a scraper, in the areas this didn't work well I got these small wheels that go on a drill from silver auto, there like a fine abrasive cloth material they worked well, just be carefull to remove the debris only( emery cloth would work to). Fill the cylinders with rages before you start and vacuum out when done. Wipe down the head and block mating surfaces with a cloth wet with lacquer thinner or acetone to remove any last bits of oil before you put it to together. Also remeber to suck out the stud holes in the block before you thread them in. I hope that helps, good luck.
To get the build up on the block off, use the coarse side of the stone on the edge and scrape it off. Use some water, helps keep the stone from plugging up. Once you get that done, flat stone it with the coarse side, will take off the high spots, and then use the fine side and it will finish it off.
Jamie we are just using a cut modified gasket in our common rail trucks when we do the heads on them. I can get you the gasket in that you ned and the one that PDR told us to use for about 140.00 I run this gasket in my truck and have had no problems with it.
Aaron
Aaron
I got a sweet deal on this 10 thou over gasket from PDR because they took so long on my head. I will defiantely come to you guys for the next stuff I do on this truck. Though, I was wondering if you can get a twins kit that use my existing HTT turbo?
Which HTT turbo are you running? I should possibly be albe to get a twins kit for your turbo that will work. Let me know all the specs of your turbo and we can go from there.
ted_pulliam
07-16-2009 12:33 PM
jmccart
14
08-01-2008 12:46 AM
wildchild97
09-25-2007 03:44 PM
