24v smoke cloud
Old 06-18-2006, 10:28 AM
crisko182's Avatar
24v smoke cloud
what is a good way to make my 24v smoke more
Old 06-18-2006, 10:36 AM
jiMMyCTD's Avatar
step 1: take wallet out
step 2: buy lots of fueling goodies
step 3: smash the gas
my 99 will cloud the street on 5x5 as i row the gears. even more so on 3x3 pulling 7k if i dont let the turbo catch up.
more smoke = more fuel. sooooooooo injectors/fueling box/
remeber it also creats more heat. so you have to toss some coin at the air in and out area as well.
j
Old 06-18-2006, 10:45 AM
crisko182's Avatar
what is a good fueling box to get
Old 06-18-2006, 10:55 AM
rebal's Avatar
get a smarty and set it on #9 =smoke ...need more smoke add injectors. GOT GAUGES?
Old 06-18-2006, 11:02 AM
crisko182's Avatar
no gauges at this second should be getting the gagues in about 2-3 weeks
Old 06-18-2006, 01:11 PM
Registered
blackdiesel's Avatar
get a set of 150 hp sticks and a used edge comp. then unplug the map sensor on the box and you'll have lots and lots of smoke. like fog-a-4-lane smoke
Old 06-18-2006, 01:15 PM
crisko182's Avatar
i have a banks big hoss chip on my truck right now, my friend gave me a diablo power puck, it is not installed on my truck but i was wondering if it would make sense to stack the banks with a diablo power puck
Old 06-18-2006, 01:34 PM
KVD
KVD's Avatar
Ok what does unplugin the map sensor do??
Old 06-18-2006, 01:39 PM
Registered
it dumps the fuel it would normally dump in at full throttle, in at off-idle. Basically it dosnt need the boost to dump fuel in the motor. it does it anyways
Old 06-18-2006, 04:09 PM
12valve's Avatar
P-pump it! with a 913, or stoopid pump
Old 06-18-2006, 07:25 PM
Dieseldude4x4's Avatar
You mean like this?
https://www.dieseltruckresource.com/...php?photo=3800
I'm trying to get it to smoke a little less. Tim has another set of injectors that should clean it up a little.
Oh and don't ask what it took to get it to that point.
Old 06-18-2006, 07:38 PM
crisko182's Avatar
Originally Posted by Dieseldude4x4
You mean like this?
that is awesome is that a 12v or a 24v truck
Old 06-18-2006, 07:47 PM
Look at my sig in the post above. It's a 99 with right at $11,000 in engine work.
Old 06-18-2006, 07:53 PM
The first pic was taken when I had literally just got the truck back from Scheid (drove it home from Indianapolis that morning) with about 1000 miles on the rebuild.
The pic below is two years later (Claremont roundup #3 two weeks ago) with about 25000 on the rebuild. Looks like it cleaned up a little and picked up a little more HP too once everything seated in a little.
https://www.dieseltruckresource.com/...cat=536&page=1
Old 06-18-2006, 11:38 PM
ASTAR's Avatar
My truck smokes like an old school locomotive below 1700RPMs at full throttle with the SMARTY on 8 and the Comp on 5x5.
Go ahead, tailgate me!
Quick Reply: 24v smoke cloud
