24v nozzle install pics?
Ive been researching changing injector tips with out a whole lot of info. anyone with some good info would be great, and pics would be better. thanks. Dan
oh, by the way I work for Cummins and I can see the pop tester from my desk
Here you go.
Dan,
There is a slot cut into the top of the injector body on the 24V injectors. You need to use a piece of bar stock that is the same diameter and use that in a vice to secure the injector body from moving while you untorque the nozzle with a 15mm socket.
After that its pretty straight forward from that point on.
The torque I use on the nozzle nuts is 35ft lbs.
9 sec camaro
09-26-2006 10:13 PM
mkrenn
02-12-2006 08:23 PM
