24v mechanical pump conversion
OK, I know this topic has been touched on alot as of recently, but I still have some questions and concerns. I basically wanted to get some good hard facts about this conversion. I want to know the cost and what it takes to put it all in. Like is there any major modifications that have to be done...etc. Also for someone like me who wants moderate hp gains and does not drive there truck much, is the FASS worth the save in money. I am in college and on limited funds until I finish my studies but I also like my hobby and make enough money to have fun. But anyways, my next step in the mod list is to better my fuel system so that my vp doesnt crap out when i put on the edge comp hot and some injectors...hopefully I am making sense here. basically i want to know comparison, if there is any, and if for my application the fass is fine or not...or is the mechanical pump it???
Thanks for the input ,
Kevin
Kevin
Kevin, if you are still in College, a P-Pump conversion is likely not for you. Thw swap can be REALLY expensive. P-Pumped trucks tend to be big HP and big dollar rigs and not really daily drivers..
Kevin
Kevin
DTR Advertiser
The FASS is less cash. They fail, but not like crazy or anything.
The conversion to a mech pump is basically bulletproof. My mech pump had 200,000 miles on it when I took it apart to rebuild it and it was NOT worn at all. I put it back together and it is ready to go again. It had NO wear. A 24 V engine needs a cam swap to run the mech pump. This forces you to, purchase a cam. The mech pump is around 160 bucks, the cam is around 700 and line kit and other parts needed come to about another 150 or so with gaskets spacers, etc. So its over a grand. A FASS is like 600 or less, but you dont get a cam and you dont get the line kit all the way to the VP44 to replace the banjo bolts, etc.
Its a hands down win for the mech pump conversion when you look at everything like reliability and value, but it does cost more than just an electric pump.
Don~
Don~
Ok....a little confusion here...maybe I read the original post wrong??
heavyboostin, are you talking about converting your electric lift pump to a mechanical lift pump (12V style) or are you talking about getting rid of your VP-44 and going with a P-7100 Injector pump??
I believe he is referring to the mechanical lift pump as he mentions the FASS in his original post.
The mechanical pump is the way to go for reliability. Don's system with a cam or the Rasp is also a mechanical pump.
A lot of people run Fass and Fass II which come with a decent warrenty. I just mounted a oem pump to the frame with the Vulcan kit. Jegs sells a simular kit with a Holly pump.
Just depends on what you want to put into your truck. I get 15+ fp at idle with the stock pump relocated
Another advantage to consider besides the mechanical pump is a new cam will improve the engines ability to breathe. Your turbo doesn't have to work as hard and you'll get more power with less boost. It's initially more expensive than a fass but you won't ever have to buy another lift pump. Over a period a say 5-6 years you could potentially buy two fass pumps which would equal the cost of the cam conversion without the benefits of the cam.
Thats a good idea, so you are replacing the cam...hmm sounds like more work than I want to do at the moment...maybe ill just go with the FASS for now and see how it holds up...Like I said I dont want anything to serious right now, Just a truck that runs decent and put donw a lil smoke from time to time...and looks good, being in college I dont have alot of time and money to devote to my truck...thanks for all yourhelp guys and sorry for the confusion in my beginning post, I forgot to specify which pump I was talking and I just assumed...
Thanks,
Kevin
Thanks,
Kevin
The Guru
If your low on bucks an electrical carter pump is the cheapest route. Its not gonna last for long, but will last until your done school. Install a cheap pressure gauge. Your cost should be under $120 for everything. It isn't fancy or exotic but will work.
stock600
04-08-2008 11:30 PM
VIPERBLUELX
08-06-2006 01:54 PM
Super4x4Duty
10-29-2004 07:04 PM
ddestruel
13
08-17-2004 03:38 PM
