24 V Performance
Re:24 V Performance
[quote author=dodgeboy59td link=board=7;threadid=14853;start=0#139326 date=1053207977]<br>Is there any other boxes that i could stack with the Edge Comp? Thanks Wes<br>[/quote]<br><br>You could stack a VA in there since it plugs into the injection pump. However I wouldn't do it.<br><br>You can do injectors to compliment your box.
Re:24 V Performance
[quote author=KatDiesel link=board=7;threadid=14853;start=0#139352 date=1053216091]<br>[quote author=dodgeboy59td link=board=7;threadid=14853;start=0#139326 date=1053207977]<br>Is there any other boxes that i could stack with the Edge Comp? Thanks Wes<br>[/quote]<br><br>You could stack a VA in there since it plugs into the injection pump. However I wouldn't do it.<br><br>You can do injectors to compliment your box.<br>[/quote]<br><br>Since the Edge Comp already contacts the pump wire, stacking another box wouldn't do much.<br><br>You could upgrade the Comp to a Drag Comp to get more power.<br>Injectors are always a good thing, something in the Supermental class would be a good thing.<br><br>phox
Re:24 V Performance
[quote author=phox_mulder link=board=7;threadid=14853;start=0#139435 date=1053234412]<br>Since the Edge Comp already contacts the pump wire, stacking another box wouldn't do much.<br>[/quote]<br><br>A VA doesn't contact the pump wire, it plugs into the back of the injection pump. However I still wouldn't do it
![Wink](https://www.dieseltruckresource.com/forums/images/smilies/wink.gif)
Re:24 V Performance
[quote author=KatDiesel link=board=7;threadid=14853;start=0#139485 date=1053261456]
[/quote]
A VA doesn't contact the pump wire, it plugs into the back of the injection pump. However I still wouldn't do it![Wink](https://www.dieseltruckresource.com/forums/images/smilies/wink.gif)
[/quote]
I did not know that, but as for the not doing it, maybe below is a good enough reason.
[quote author=Trashdawg5050 link=board=7;threadid=14853;start=0#139639 date=1053300224]
I stack a VA and a comp and gained 10 lbs and 1 hp. The heat was the same
[/quote]
Kinda pricey 1 horsepower there.
As for the 275 injectors, may people have said it's a nice kick in the pants, makes the engine behave like it should from the factory. Not a huge difference, but noticable.
phox
[/quote]
[/quote]
[/quote]
phox
Re:24 V Performance
My truck last week made 266 Hp with just 275s. And with the VA 303 Then I turned on my Egde three stage box and it made 319. But with a comp and VA I made 335 HP and 835 tq. I like the 275s for a light to mild combo.
Re:24 V Performance
An EZ and 275's/DD2'S seem to be the norm for a mild upgrade. The DD2's and EZ may tax the tranny to much. Most go with the EZ/275 combo. Makes a nice 90 or so hp gain and a slight increase in mileage while still having manageable EGT's (make sure you have gauges though).
ladyram
03-22-2003 12:53 PM
