235/85-16 tire upgrade questions
Has anyone gone from the 225/75-16's to 235/85-16's and if so did your fuel mileage improve on the highway? If not, did it go down? and do they clear ok?
Thanks
Eric
Thanks
Eric
235/85/16 will improve mileage, all else being the same. Less aggressive tread will always get the best mileage. No problems clearing 235's either. I can't believe that your running 225's that must look funny!
You can clear up to 305/70r16 with no rubbing. Now it depends on what gears you are running if your fuel milage goes up or down. If you got 3.55 then you fuel milage will go down or up with 4.10. If you are only looking to go to the 235 then you should have no worrys about fuel milage. I dont think it will be enough to even notice.
Gearing won't really determine if your mileage goes up or down with tire choice. That's largely because the diesels have variable air/fuel ratios, so when the engine is loaded harder (taller gears) it burns more fuel, and at lighter loads (shorter gears) it burns less (runs leaner).
For mileage, you want a tall, thin, hard tire. A 235/85 is pretty much the champion of MPG for tire sizes, assuming you are comparing the same load ratings and tread patterns.
A tire that puts more tread on the road has higher rolling resistance, and thus lower MPG on the hwy. A larger tire also weighs more, and therefore takes more energy to get rolling (which is then wasted as heat when you hit the brakes).
I don't know about funny, but I think it would also look better with the 235's
I would imagine you'd have trouble keeping those 235s planted to the road with that juice!
You must have a lot of self control driving with those 225s now. Those things are pizza cutters.
![Cool](https://www.dieseltruckresource.com/forums/images/smilies/cool.gif)
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
It had snowed here and all that power with those 225's just did not work out. When it finally gets back from the bodyshop I am going with the 235's.
I'd recommend the Toyo M55s in a 255/85 size. They will fit on the factory 16x6.5, 16x7.5, and 16x8 wheels and will clear without a lift.
They will give you taller overall gearing (the same as a 285/75), wear like iron, and have good snow traction.
I'm considering them myself. Either this size or the 285 (since I have factory alloys that can handle a 285).
Justin
Justin
Justin
Justin
I agree but I don't drive that fast![Smilie](https://www.dieseltruckresource.com/forums/images/smilies/smile.gif)
BB24-- If you look at the recommended rim widths, most manufacturers say 8" wide is the minimum for a 315, and that 7" wide is the maximum width for a 235/85.
Thus, those who have the 01-02 alloys like me should not be running a 235/85 tire.
Neither should you be running a 315 on a 7" wide wheel, mister
