.22 shell or boost elbow
.22 shell... (block off the signal line) as long as it doesn't go over ~36psi, you're fine... with a 160 pump and stock injectors, I think you'll be fine even w/ the 10 full forward... your TRANNY might not be fine, but from a turbo/boost standpoint, you will.
Forrest
Forrest
as long as you run the stock injectors you will be fine no matter where you put the plate. with 300 marine injectors and my plate in stock posi. I was getting around 35-38 PSI of boost.
DM01
DM01
I did mine right where it goes from the pump overthe top of the engine. some trucks are a little different but basically anywhere between the Cold side of the turbo and the WG.
DM01
DM01
Don't know about the 12v, but on mine, I simply removed the elbow on the turbo, and put in a plug(1/8 npt) and caped the elbow so no dirt gets in it, so I can hook it back up if needed.
dodgediesel
14
12-14-2006 09:54 AM
TorqueJunkie
15
08-30-2006 09:15 PM
RockcrawlingTJ
07-22-2006 05:11 PM
triplenickel
08-23-2005 04:01 PM
Palmetto_kid
01-16-2004 02:21 PM
