22.5 tires on 22s.....
Old 06-02-2016 | 04:25 PM
Arwhite's Avatar
Originally Posted by 1-5-3-6-2-4
not safe not safe not safe...........waiting to peel the tire off the rim while rounding a corner is he? cause it will sooner or later.
this is the profile of a 24.5 alcoa, but they're the same as 22.5/ notice the taper of the bead seat. the tires match that seat. "passenger vehicle" rims have a much more vertical seat - 90 degrees. for bead retention. class 8 rims and tires are designed for huge loads straight down through the sidewall and beadseat. thats 80,000-120,000 of loaded truck is what keeps the beadseated on the taper. and the taper has a larger surface area of contact for load distribution and bead retention.
heres my 22.5 alcoas turned down to 22.0" with Nitto 420s 305/45r22 on them.
Do you know what the thickness of the wheel is after its turned down. .... best i can tell mine will only be about an 1/8" thick
05-29-2009 11:24 PM
DODGEKID
06-30-2007 07:10 PM
sakisaki400
23
12-31-2006 11:17 PM
Captain
09-09-2005 01:16 AM
