215 Pump (913) Timing Question???
Old 03-29-2007 | 02:12 PM
signature600's Avatar
How much lift is 20* timing??
Right now I'm at 6.0mm lift, but I started at 6.7mm...6.7mm was WAAAAYYY too high for me. Lots of rattle, but she ran really good above 4K all the way to 5500RPM. 6.0 feels better, but I think it might be a bit high yet, which doesn't make sense because 5.6mm is 16*, 6mm should only be about 18 by my math!
Anyone know for sure??
Thanks in Advance,
Chris
Old 03-29-2007 | 03:33 PM
gunracer1's Avatar
that is 18 by my charts, i had 20 on my 97 and i really liked it with the big single. but i poped the head gasket.
Old 03-29-2007 | 03:38 PM
That's what I was thinking...where did you set it for 20*??
Thanks Gunracer1,
Chris
Old 03-29-2007 | 03:56 PM
RonA's Avatar
Chris.
The pump shop set mine at 19.2degrees. That measures out at 6.1mm on my 887 pump.
Ron
Old 03-29-2007 | 04:22 PM
gunracer1's Avatar
6.2mm of lift, the truck really likes it. and it revs like a small block chevy.
Old 03-29-2007 | 10:30 PM
BCB's Avatar
BCB
wouldi pop a head gasket with 6.2mm and 55-60 PSI on a stock gasket with studs?
Old 03-29-2007 | 10:40 PM
Crawler's Avatar
More than likely, yes you would.
~Wes~
Swamp_Donkey
09-03-2009 12:05 AM
Jambbii
21
08-07-2006 05:24 PM
ddestruel
03-03-2006 09:03 AM
signature600
02-21-2006 11:54 AM
