215 injectors w/ DVs..
Old 03-18-2006 | 04:11 PM
RedRotors's Avatar
Hi there,
I read a lot of threads but i can't find any clarification.. I will install 215hp sticks on my truck and by the same time, i want to upgrade the DVs.. I cannot make my mind between 181s or 191s. I have the stock charger w/ 12cm housing. I don't care much about the smoke, but i don't want the EGT to the roof..
181 or 191? That's the question..
Marc/
Old 03-18-2006 | 04:12 PM
singleturnout's Avatar
what are dv's if you dont mind me asking
Old 03-18-2006 | 04:53 PM
BCB's Avatar
BCB
Delivery Valves
Old 03-18-2006 | 04:59 PM
cool thanks
Old 03-18-2006 | 05:27 PM
kawi600's Avatar
the 191s are a good idea if you go to 370 injectors later on, but the next smaller size should work ok on the 215's.
Old 03-18-2006 | 05:35 PM
Willy91's Avatar
I would go with 191's.
Old 03-18-2006 | 07:39 PM
TxDiesel007's Avatar
191s are good
But if you are gonna add larger than 30 injectors or some serious turbo, why not laser cuts?
Rick
Old 03-18-2006 | 08:25 PM
RedRotors's Avatar
My goal is around 300-350hp and keep the stock charger..
Marc/
Old 03-18-2006 | 08:27 PM
Willy91's Avatar
Originally Posted by TxDiesel007
191s are good
Rick
Running laser cuts on the stock turbo would get hot wouldn't it?
Old 03-19-2006 | 06:23 PM
signature600's Avatar
I ran 322hp with 181's and 300's and a B1...I'd say go with the 191's, keep your stock sticks, and hybrid that turbo!! Should be over 300 fairly easy
But I've went to Laser Cuts now...I'll never go back
Chris
Old 03-19-2006 | 07:41 PM
Cummins Freak's Avatar
ok quick question where di i get DV's who has them on their web site i'm thinking lazer cut
Old 03-19-2006 | 07:57 PM
Willy91's Avatar
I got mine from these guys.
http://www.enterpriseengine.com
Old 03-19-2006 | 07:58 PM
thank you that helps
Old 03-20-2006 | 05:53 PM
RedRotors's Avatar
Chris
Well, i'll swap the sticks.. I have a 94, and i have a set of new stock 215hp in my garage.. I guess i'll go with the 191s.
Thanks guys..
Marc/
Old 03-20-2006 | 05:57 PM
Mcmopar's Avatar
Marc/
See my sig. Just buy the 370's and you will be there!!
