2003* anyone knows how to raise the front 1-2"?
just wanted to see if anyone has raised the front of their 2500 1-2" to level out the look of their truck?seems that it would be easy,and i dont want to lift it,just level it.spring spacers?who may have such an item and where could a fella get them?thanks!
Re:anyone knows how to raise the front 1-2"?
Spring spacers are indeed your answer. Tons of guys run them, with no problems. The only issue, as you can imagine, is when you load up the bed or hook up to a heavy trailer, you will now be nose-high rather than level. Not really a problem unless you tow at night, then expect to get a few bright flashes from oncoming traffic. As far as where to get them, just about every suspension mfg out there makes spring spacers, and you should be able to pick a set up for around $100-$150. Installation is very straightforward, and it really helps if you have heavy-duty spring compressors. I have a picture of the spacers and stuff installed on my webpage if you want to check that out? http://www.geocities.com/tobyw2000
I'm loooking at this(http://www.jackit.com/store/cat.cgi?s=dg135dx) leveling kit. Comes with Bilstein shocks and an upgraded steering stabilizer.
redneck2thamax
10-24-2007 04:23 PM
PEAKSTRYDE
10-11-2007 04:20 PM
barryp
18
02-13-2007 05:34 PM
