2002 Fuel pressure gauge
I have a 2002 Dodge and have bought a fuel pressure gauge.Where do I tie this into.Is there a place on the filter or on one of the lines.Help!
Casey
I have mine tapped into the Vp-44 test port. Picked up a banjo bolt and the pressure switch screwed right into the end of the bolt. It took about 2 min.
Either place mentioned works fine on a 2002, I prefer the bottom of the fuel filter, as it leaves the test port on the VP44 open for just that, testing, good place to hook a temporary guage if you think your permanent one is failing, and leaves the test port open for Dodge to check if you need to take it in.
1999 on the other hand doesn't have the bottom of the filter option,
it does however have two test posts on top of the filter that work great.
One is prefilter and one is post filter.
Rattlinram has posted pics of his dual guage setup a couple times, most likely has a pic of it in his photo album here.
phox
phox
dodgeguy71
17
01-19-2012 12:52 AM
Greeds22
25
09-11-2005 03:13 PM
engcogod
17
02-03-2005 08:49 PM
Patriot_RAM
10-08-2004 06:10 PM
