200 sticks with 64mm
I haven't ran that setup, but 200hp injectors should be very well matched for a 64mm.
What size turbine wheel and housing? What size injectors are you running now and what egt's at WOT?
On a VP truck you want a cam 188/220 or smaller. Hamilton Cams has the 188/220(best from idle-4200), or 182/214(gives up power to 188/220 after 3500) for a little better low end(less smoke) while compromising a little power, or their 178/208 for the highest efficiency(lowest smoke) possible but it give up power to the bigger cams after 3k rpm even though it will still make more power the the stocker.
blwnsmke
49
05-25-2008 11:39 AM
