20" rims and 35" tires??
hey can i fit 20s wit 35 in tires wit just a leveling kit? also if someone wit a newer 2nd gen is runnin eagle alloys series 064 rims id like to see pics of it.. i love those rims!
The rim size doesn't matter. Check the tire dealer website to get the actual tire height. A 35" tire is almost never 35".... I would say that 33.5" to 34" is the biggest you'll get on a stock suspension with no rubbing. Mine is at 33.5" tire height with only a skosh bit of rubbing on a full lock turn (the plastic fender liner in the front barely gets rubbed). 20" rims generally mean you will get a harsher ride (than a CTD truck? No way....) and more expensive tires....
I had 34.4"x 13.50's on my 3rd gen with a revtek leveling kit and they rubbed slightly. You can fit them with some minor cosmetic trimming. I also think that if you dont go as wide (like a 12.50) that you should be good. I also had 20" wheels but like sherrif said already, the wheel size doesn't matter.
it is the back spacing that will kill you. i have 33" with 2inch in the front and 2" in the rear and the only clear buy a 1/2inch on the fender when the wheel is turned. but ihave 4.5inch back spacing -19mm offset. so i have everything working agianst me getting bigger tires and my wheel is 9.5 inches wide
danny
danny
same as <<Dwitt0187>> said but i run 20" mkw's with 35" x 12.50 toyo mt's and i have never rubbed not even off road just a leveling kit its all in the offset i tried a bigger offset first with same tires cause i think they look better but they didnt even turn all the way cause they hit the fender i'll find out the offset i went with and let you know k......... if you do the same as me you'll be fine
what about a small body lift like 2-3 inches for a little extra space between the tires and fenders. Anyone have a body lift in their truck is it ok to do does it cause problems cause I was thinking about doing a body lift myself for a little more hieght.
05-29-2009 11:24 PM
PEAKSTRYDE
10-11-2007 05:20 PM
VikingDiesel
47
05-11-2007 01:52 AM
sakisaki400
23
12-31-2006 11:17 PM
Erska
10-16-2006 10:29 AM
