2-stroke mix
Old 11-18-2008, 11:59 AM
nkennedy's Avatar
I don't think it helps the P pumped trucks, but the VP44 trucks should benifit from the 2 cycle oil. I run 1oz to 1 gallon. No problems with it so far, but there is a little smoke. P pumps are engine oil lubricated, VP44's are fuel lubricated.
Old 11-18-2008, 05:32 PM
12v rollincole's Avatar
i ran 16oz in about 25 gallons once, didnt feel any difference, my fuel mpg is always good and didnt change. might have been alittle quieter, but then again that was only 16oz.
Old 11-18-2008, 07:40 PM
jcarrillo's Avatar
The cam is lubricated by the engine oil but the plungers and barrels that inject the fuel aren't.
Old 11-18-2008, 07:46 PM
jentas's Avatar
I just finished running a tank with only powerservice in it down to almost 1/4, and I didn't add anything since the last fill up. Maybe the shift to cold temperatures is causing some of this, but it's amazing just how much louder the truck is right now compared to when I had been running consecutive tanks with 2 stroke oil in them.
I wish I had one of those decibel meters to see just how much quieter it runs when it's 2strokin again.
Old 11-18-2008, 10:54 PM
imbodie's Avatar
Decibel meter
You might try running by a local audio store... bet they have a meter for checking stereo's ...... If you do test the levels... post it back... would be REALLY curious
-Tim
Old 11-19-2008, 08:59 PM
bridleman's Avatar
So what is the exact kind of 2 stroke to run does it have to be tcw 3?
Old 11-19-2008, 09:00 PM
bridleman's Avatar
Old 11-19-2008, 09:03 PM
bridleman's Avatar
oops my finger got a little trigger happy
Old 11-19-2008, 09:13 PM
atc250r's Avatar
I use the gallon jugs of Wal-Mart's "SuperTech TCW-3" oil. I haven't seen any improvement in fuel mileage but it does seem to quiet the pump down a bit. I don't add it for the noise though, I just want to keep my pump happy.
Old 11-19-2008, 11:14 PM
97dodge12v's Avatar
my dad has a meter to measure noise levels, i will try this and post back to see what it does
Old 11-20-2008, 09:28 AM
gotslicks's Avatar
i put 20oz to a full tank in the 03 shop truck w/530000 last fill up
i first thing i noticed was a decrease in engine noise at start up in the cold morning.
usually it pretty loud for 8-10 minutes in the morn when its cold.
it was only loud for like a minute or 2 before it quieted down.
i have to say it was a noticeable difference.........ill post if i get a mpg increase after i put a few hundred on it
Old 12-06-2008, 10:50 AM
gotslicks's Avatar
update
our shop truck in city driving went up 2mpg so far
engine noise in has been greatly reduced in a cold motor
25-35 degrees not plugged in at startup is so quiet i cant even believe it
Diesel Dave2
03-14-2011 08:23 PM
Common
04-05-2008 01:13 AM
JRAPTOR04
23
10-21-2007 01:57 PM
ddestruel
01-12-2005 12:19 PM
wanadieseltoo
02-19-2003 09:01 AM
Quick Reply: 2-stroke mix
