1995 Ram diesel
1995 Ram diesel
I tow a fiver and my total weight on a big scale was 7100 Kg or 15656 lbs in a total for .2500 4x4 auto with dan 70front and a dan 80 rear.I have added to the truck MBRP cool duals 4" to 4" and 5" tips. Afe power cold air and a number 10 torque plate.Steering box mod and killer pin has a tab on it.
Just what would my hp be and torque with this set up?????
I don`t know what to do next Thanks Don T
the 47? has a shift kit and pulls nice I just have to watch the skinny petal in lock up at under 50 mph. The tc will slip and trans temps climb now pulling up steep hills. I will add another trans cooler and a fan to help keep that in check.I love my truck.
Administrator/Jarhead
Yeah, you'll need more tranny mods. Once that TC starts slipping, it does not get any better. Causes a lot of heat when it slips. An external cooler won't help, it's just a band aid.
You have a shift kit, now get a heavier billet TC for it, Reduces heat transfer to the engine and better MPG and power to the wheels. I installed a Derale fan that is switched, in front of my tranny cooler. It helps.
Install cold air last night and drove 173 miles today and filled the truck back up with fuel, 6 gallons. did the math and that gets me 28 mpg, I`am happy with that and the cold air intake did make a big difference in how the truck works.
