181? 191? lazer dv's?
Are the stock DV's in a 215 pump an upgrade to a 160??
And what set would be best for towing @ 300-350 rwhp? I'm guessing 181's but I have no freaking clue...
181's are the stock delivery valves in a 215 Pump. 191's would give you a bit more fuel, and more EGT problems than 181's. You could run 191's if you watch the Pyro on long hills, then again, you could run Laser Cuts if you watch the Pyro all the time. It's all up to you, stay away from L/C's, you don't have enough air to support them.
your 160 pump has 131dv in it. The 181's will give it a boost in power however I hope to have some 191's installed pretty soon. Mybe cumminsdriver will give somefeedback he's running 191's in a 160pump and likes them as far as I know.
I can tell you from my experiance that most d-valves do give you some bump in power and boost. I will also tell you that there is a penelty that comes with them also and that is higher egt's.......
12valvedave
10-16-2009 06:17 PM
thewished
11-16-2007 06:55 AM
crankbender
26
12-25-2006 10:44 PM
