14cm non wastegated housing
Old 03-22-2006 | 09:08 PM
ellerman's Avatar
Does anybody have any experience using a 14cm non wastegated housing on an HX35? I'm considering going this route because it is way cheaper than a wastegated housing and I really would like to drop my egt's while towing on big hills. I have the edge boost fooler elbow on my turbo right now and that pretty much blocks off the wastegate but I don't know if going with a housing that doesn't have a wastegate at all will be a mistake. Also, I don't really want to go to a different turbo because of my exhaust brake. Please comment if you have experience with this. Thanks, Eric
Old 03-22-2006 | 09:16 PM
infidel's Avatar
I tried a non wastegated 14 on my 12 valve and ended up going to a wastegated one.
Boost went way higher than the 35 psi I desired, was afraid I was going to toast the turbo.
My opinion is that you need at least a 16 cm before you can skip the wastegate but then you suffer slow spool up.
Old 03-22-2006 | 09:28 PM
I'm with Bill on this one. But by the time you get the 14 cm WG housing, you are nearly halfway to a better turbo. PDR sells a B-1 type turbo with an HX-35 outlet, you might condsider that instead.
Old 03-22-2006 | 10:14 PM
cumminsdriver635's Avatar
Either leave the stock 12cm housing, or get a better turbo. I went down that road, and that is my .02
Eric
Old 03-22-2006 | 11:03 PM
hotmopr's Avatar
I am looking for one.. I already have a wastegate..
Old 03-23-2006 | 09:27 AM
kandgo's Avatar
I am really satisfied with the performance of the 16cm non waste I have on mine, As far as slow spool up I noticed a slight difference but after the 4in exhaust install it helped put the spooling back almost to the 12, where it shines is pulling our trailers as egt's are a concern. I use my trucks for pulling trailers and such not romping them around so that is where the 16 non will help allot. Goodluck,,Rick
Old 03-23-2006 | 12:20 PM
For a 5spd, the 16cm housing is probably a little better. Its just hard taking off with a load with a tight converter, and the bigger housing. Once it spools, its fine; but it can take a minute to spool depending on your converter.
Eric
Old 03-23-2006 | 01:43 PM
HOHN's Avatar
The problem with high EGTs isn't *just* the tight housing.
It's the fact that the turbine side itself is pretty restrictive.
Better to look at a larger turbo than just a 14 ng housing.
12wg is a better option than 14ng IMO for EGT control AND spoolup....
sooty
10-13-2010 10:14 AM
jrussell
06-15-2006 12:04 AM
caleb c.
11-25-2004 01:04 PM
boughtadodge
05-31-2004 10:20 PM
dart440_72
07-12-2003 01:23 PM
