14cm downpipe flange
I am building a set of twins for my truck (99 24v) and am using an HTT 14cm nonwastegated turbine on the hx35. What no one can seem to tell me is what size vband clamp the outlet uses and where I can find one. As well as hopefully a matching flange. Not looking to turn one on a lathe... Do first gens use a flange like this?
TIA.
It's this housing fwiw.
TIA.
Its the same flange as the H1C, WH1C,and early HX-35
Not the same as the HX-40
Its the same flange and band as a 89-98 12 Valve. the 94-98 12valve used a cast neck to convert to the 2 bolt flange but the housing was the same as the 89-93. On the 98-02 24-valve the neck was cast onto the back of the WG housing and used the 2 bolt flange
here is a flange that has been machined to fit a 4" pipe.
http://cgi.ebay.com/ebaymotors/4-HX3...9791QQtcZphoto
I have not found a V-band for you.
If it fits the 3rd gen they have them mis labled becouse they used a HY-35 type D 03-04. Now that I look at it and you said that I can see that it is wrong for the HX-35.
So anyone have an old first gen downpipe laying around?
:edit: I've really been busy with other things lately, but this one part is what's keeping my head from being o ringed and the twins finished.
dieselfuelonly
18
05-24-2007 09:01 PM
blackvert
01-18-2007 10:27 PM
MasseyMan1089
01-23-2005 08:25 AM
