12v Valve Cover Breather
Old 07-28-2007 | 09:07 AM
signature600's Avatar
Here is the complete parts list for anyone wanting a set of the breathers I run on my truck...also, member "Hammer" runs them on his truck.
2830784 Breather Valve Cover
4899194 Crankcase Breather
4899195 Sealing Ring
3901865 x3 Capscrew <---Need x3
3930906 x2 Valve Cover Gasket <---Only if you need them!
3935449 x2 Noise Isolator/Seal for Valve cover Bolt!
3907049 x2 Valve Cover Bolt<---Shorter than older style
Also, about 5' of 3/4"Id hose depending on routing!
Thanks Hammer for the pic!!!
Chris
Old 07-28-2007 | 03:04 PM
24Vford's Avatar
is there any real bennifits for them i was thinkig of doing that to my 24V but was unsure if would e of any good
Old 07-28-2007 | 07:27 PM
TheMighty'67's Avatar
How much did it cost you to buy everything? And do these require grinding to clear the studs just as the stock valve covers? Thanks dude...
Old 07-28-2007 | 10:19 PM
TxDiesel007's Avatar
Chris
Awesome!
looks like a good mod to come..
Thanks chris
Rick
Old 07-28-2007 | 11:28 PM
wcbcruzer's Avatar
Looks good. What does it do?
Old 07-28-2007 | 11:50 PM
RyanB's Avatar
Great pics and thanks for the parts list. I was told there was something like those covers for the 8.3's but had never seen them in person and I was unable to find any part #'s. Going to call up cummins this week and see about getting a set. What kind of $ did they set you back???
RyanB
Old 11-22-2007 | 07:31 AM
reinerh's Avatar
RyanB
hi there,
was just curious if you ever found out what the cost is for these parts??
happy turkey day,
greats
reiner
Old 11-25-2007 | 02:01 AM
jjj_85's Avatar
Are those part numbers for a Cummins parts place? That is the greatest mod I have seen in a long time.... I have been putting off doing a front crank seal for a long time for fear of it leaking again, now I wont...
Old 11-25-2007 | 06:37 AM
prattman's Avatar
I believe those are Case tractor part numbers.
Here's the link from the TDR:
http://www.turbodieselregister.com/f...rs-before.html
Old 11-25-2007 | 08:20 AM
heykw's Avatar
How much $$$$$$$$?
Old 11-25-2007 | 10:19 AM
97' CTD's Avatar
Around 150 give or take.
Brandon
Old 11-25-2007 | 02:28 PM
Those are Cummins part numbers...but a Case dealer should be able to use them too
Chris
bishgeo
07-25-2010 02:21 PM
jeddy
02-15-2010 10:06 PM
05ChainSmoker
07-20-2008 11:20 PM
Valv
03-13-2007 09:15 PM
