12v injector install instructions
Old 11-22-2004 | 02:50 AM
Dufrain's Avatar
Does anyone have a link to 12v injector swap out instructions or is it pretty much just take the lines loose and pull out the injectors.Do I absolutely have to have an install kit,these injectors are used.Thanx
Old 11-22-2004 | 09:04 AM
apache's Avatar
Pretty much just remove them by undoing all the line clamps,feed lines to injectors, returns on front, undo the large base nut and pull en out. Yes, I would definatly use a install kit, you get new copper washers for the bottom seal and also the copper deals for the return line. MAKE sure all the dirt and crud are out before yanking them, also check the bores and the general area before they go back in to make you get a good seal. Curiouus what your putting in? my 95 needs a set.
Old 11-22-2004 | 10:33 AM
infidel's Avatar
I 100% guarantee it will be faster and easier if you unhook the return and pressure fuel lines from both ends and remove them totally. Bending them just a little makes it very difficult to line up again plus you run the risk of leaks or cracking a line. The lines are hardened steel.
I use a piece of pipe 1-3/8" long, slip it over the injector after the lines are removed then screw a wheel lug nut down on it, it'll pop right off.
Old 11-22-2004 | 10:57 AM
berner's Avatar
Make sure you clean up the sealing surfaces on the return line with some 400-600 grit sandpaper. I had some trouble with leaks until I did this.
Old 11-22-2004 | 12:51 PM
Dufrain's Avatar
Thanx guys for all The info.Im just sticking some used 215 injectors in there.I have a set of peirs 370s but Im afraid Ill get too hot egt with them and Id have to spend 200-250 for dvs and maybe 200 for a bigger compressor wheel and housing to cool them off.Maybe Ill add all that later.I still have to get those springs in there to.
Old 11-22-2004 | 09:45 PM
masonic-dodge's Avatar
Hey guys I have 2 questions
First infidel what size lug nuts do I need to use to change my injectors?
second Dufrain do you want to sell those PDR 370s, I,m getting ready to buy some injectors and I figured I'd ask. PM me if you want to sell them.
THANKS CRIS
Old 11-23-2004 | 12:06 AM
Dufrain's Avatar
I think Ill hold on to the 370s,Ill end up with a 215 pump truck one of these days.I think you just yank a lug off the front of your truck to pull the injectors
Old 11-23-2004 | 12:11 AM
infidel's Avatar
The same size that holds your wheels on
Not sure of the exact size but they are metric.
Old 11-23-2004 | 03:01 AM
Bushy's Avatar
Patron Saint of 1st gens
...Masonic-dodge....
I bet you've been to the east too... right???
W.B.- B. Coe A.F.& A. M.
Old 11-23-2004 | 07:50 PM
Bushy-
Your right I am a traveling man
infidel-
Thanks for the info on the lug nuts
CRIS 32nd degree
Idaho Guy
03-31-2005 01:35 PM
Dodgezilla
08-23-2004 05:16 AM
KenR
02-17-2003 03:13 PM
