12v guys.....edumicate a 24v guy
Old 10-25-2006, 03:16 PM
Gotlift01's Avatar
Alrighty fellas.....need some 12V help. My buddy Branden's step dad has a 98' Cummins and wants to add some juicy juice to it. I haven't really messed with a 12V before, but I was thinking about crankin up the pump and some other stuff. He doesn't want to go crazy, but just the easy mods I can do like the starwheel, GSK........how easy is the timing?
So just looking for some help on how to do it and where to start turning the wrench!!
Thanks guys
~Nick
Old 10-25-2006, 04:35 PM
Kemble's Avatar
Get him a 3K gsk and a ten plate, he will smile for weeks from ear to ear. Of course I would reccomend gauges first.
Old 10-25-2006, 05:12 PM
Gotlift01's Avatar
Yeah I talked him into some gauges cuz he tows......so a 3K GSK and a ten plate huh?? Should I mess with the cranking the wheel at all or should I leave that alone? He does tow quite a bit so I don't wanna make it to hot for him....just some more juice.
Thanks,
~Nick
Old 10-25-2006, 05:21 PM
Kemble's Avatar
the starwheel is kinda a fine tune, for the takeoff smoke. You wil have to play with to find what setting you and him like. Position the plate about center maybe just a hair forward. Mount the AFC center to just a little forward. Then you will need a boost elbow.
If you get it all togeather and decide it runs cool enough you can give him a little more, just bump the plate and AFC forward a little more.
That should make a tow rig, that runs cool, with ample power.
Brian
Old 10-25-2006, 05:23 PM
Ramdriver15's Avatar
star wheel will increase or decrease smoke for you... if he wants smoke then turn it in towards the engine. if he doesnt care leave it alone. If not done yt take out the silencer ring in the turbo, its just cool!!! Get him a BHAF or somthing along those lines... very nice purchace, imho. i havent done the timing on my truck yet but im dying to do it!!! If you want even more power than a 10 plate then you could try like a 6 or something. Then number 100 plate (i have one home ground) is very nice but the auto tranny keeps fromt he power goin to the ground. Also pinch the waste gate line or place an adjustable elbow on it.... available at tst, and ebay....lol good luck!!!
john
oh yah: do a search for all free mods... i started a post with all the free mods in it.
Old 10-25-2006, 05:44 PM
Kemble's Avatar
Remeber he isn't waning to go extreme on power, and tows. I would use a 10 plate due to the upper rpm defueling.
Old 10-25-2006, 06:29 PM
Dodge12vKing's Avatar
What does taking the silencer ring out do to the turbo?
Old 10-25-2006, 06:37 PM
dbrick's Avatar
just makes the whine a little easier to hear You will like the 3000 springs and the 10 -plate
Old 10-26-2006, 08:45 AM
Gotlift01's Avatar
Yeah the silencer ring is coming out already.......he started drooling when he road in mine and heard it screaming so he wants his out BAD!! LOL
I'm think he might do a BHAF....he was asking what was cheaper and worked so I mentioned it do him so we'll see.
So how do I slide the plate forward and put in the GSK?? I've never worked on a 12V....only 24Vs so I don't know where to start. Just a rough idea would be great and get me started!!!
~Nick
Old 10-26-2006, 10:36 AM
Is the Silencer ring there at the Turbo Housing?
Old 10-26-2006, 11:10 AM
2500's Avatar
does taking the turbo silencer ring do anything except make turbo louder?
Old 10-26-2006, 11:14 AM
Gotlift01's Avatar
Yeah the silencer ring is in the opening on the turbo......take the hose off for the air intake and you'll see it inside the turbo. There is a snap ring that holds it in place so just use a pair of needle nose pliers and a screw driver and work it around and it'll pop out.
And no it doesn't do anything for performance, all it does is make the turbo louder......which is sweet!!
One thing I did notice when I took mine out though.......the turbo won't shudder ( bark ) near as much as it did with the ring in. Which is a very good thing. Turbo bark is hard on the turbo!!
~Nick
DL1221's Avatar
Don't forget the timing.
I think the general consensus is that 16 to 17 degrees is the ideal, even for towing heavy. If you advance the timing, and do nothing else, like me, you'll be surprised at how much better the truck runs. You can have it done, for about $200, or spend from $40 to $300 to buy all the tools to do it yourself. Do a search for timing on the 12-valve forum.
Two things I believe every 12-valve should have, 1) Fix the KDP, 2) advance the timing.
Old 10-26-2006, 02:53 PM
TxDiesel007's Avatar
COuldnt agree more with the last statement
But the third thing is add a GSK to it and really wake up that ride!
Rick
Old 10-26-2006, 04:37 PM
dbrick's Avatar
I wouldn't recommend any more being done other than whats mentioned above without a clutch upgrade. That stock clutch will be hateing life. It was a stick wasn't it?
Quick Reply: 12v guys.....edumicate a 24v guy
