12v Boost gauge questions
Old 06-29-2004 | 01:46 AM
Towrig's Avatar
Question 12v Boost gauge questions
I searched and searched and searched had had no luck finding ideas of where to tap into the intake for my boost gague. I just got my Pyro dialed in and I have boost and Trany left.
Any place better than another to use for the boost? Pic would be cool. TIA
Andy
Old 06-29-2004 | 05:14 AM
smokin habit's Avatar
look behind the injector pump there is a small plug in the head thats where mine is
Old 06-29-2004 | 06:13 AM
infidel's Avatar
Injector lines and air intake removed for clarity, you don't have to remove them.
I perfer to use a 1/8'' x compression 90° rather than the straight fitting supplied with most kits. I also feed the small boost tubing through a larger tubing to protect it from cuts and abrasions. Also makes it easier to route without kinking.
Old 06-29-2004 | 10:15 AM
Towrig's Avatar
What kind of boost am I looking for when I get this bad boy in. smokin habit
and infidel thanks for the input I like the Pic!. It seems like the new guys have a hard time getting anyone to help, I am not sure if its just old news or If just because I dont know anyone??
Old 06-29-2004 | 10:38 AM
infidel's Avatar
If you haven't installed a plate or boost elbow the factory max setting is 18 psi for your truck. You'll find the stock specs for your truck here-
http://dodgeram.org/tech/dsl/Facts/94specs.html
Old 06-29-2004 | 11:19 AM
aklabs's Avatar
Also you can go to the TST website. They have directions for installing both the boost and pyro. Their wesite is
http://www.tstproducts.com/gauge_install.html
Hope this helps.
Dawna
edited for correct website
Old 06-30-2004 | 12:46 AM
Towrig's Avatar
Good deal thanks. I have been reading up on those sites....great info for sure. Now if I could just get the 1/4 allen head off of my PacBreak I would be in good shape. I Broke one allen off already and now the stud is stripped out...
mr.mindless
16
09-13-2009 01:02 AM
Tank_66
02-28-2008 09:34 PM
turbomike
12-03-2007 10:31 PM
DennisT
05-11-2007 09:58 PM
CRXsi
03-31-2006 08:56 AM
