120hp edm's
#32
Originally posted by oestreich84
Here is the problem. I have a budget of about $1500-$1700 right now. If I would get the Mach 4s that wouldnt even leave me with enough for a clutch.
With your budget restraints...you would be better off considering non EDM's. There are lots of DD injectors out there at great prices. We all played with them for years...before EDM's came along.
Good price ($300) on some 80 hp's here... http://www.turbodieselregister.com/c...uery=retrieval
275's for $325 here... https://www.dieseltruckresource.com/...threadid=75609
RJ
#34
Do you know which 1? I called earlier this week and they have 3 available. Would it hurt anything if I went to a 125gph over a 95 gph?
180-P4600HP
http://www.jegs.com/cgi-bin/ncommerc...10&prmenbr=361
#35
Well I bought a set of new 100hp DD Nozzles on e-bay last night for $200. I was also looking at the van aaken smartbox r for $265 but I didnt get it. Maybe next week Will I notice a nice improvement over stock even without a box? When I do buy the VA, will I need to upgrade the clutch right away, or will the stocker hold long enough for me to save some more money and get a sbc? Anyone running the 100hp DD nozzles? Do you like them? I am finally on my way to the 400 hp club
#36
i guess my main question is if i should wait to install the nozzles until i get a box or if i will notice any improvement with the rest stock.
#37
Put the nozzles in. I am very happy with my Jammers. I have no EGT issues empty level ground anyway. I have had to back off once going from around 1500 to 2700 RPM on a decent grade. I just wish I had a box and turbo to make full use of them.
Randy
Randy
#38
1. I am planning on getting a fass system on my truck in the very near future. Is there anyone in western Wisconsin or eastern Minnesota that has done the install before and could help me?
2. I bought a new Van Aaken smartbox r off ebay for $245 this weekend. Will I be ok for a little while running both the box and the nozzles on the stock fuel system? Or should I just install 1? Which 1 should go on first?
3. I guess I bought all this stuff in the wrong order but i just couldnt pass up the good prices I guess I need to know if I should wait to install any of this stuff until I get my fuel system up to the task of handling the mods.
4. I am also going to order a new set of gauges this week. Which ones have you had the best luck with? I was looking at ordering the autometer cobalt series boost, pyro, and fp gauges. I want to run a mechanical boost gauge like I have now, but was wondering about running an electrical fp gauge. Is this a bad idea?
#39
Any suggestions on electrical or mechanical gauges or any other stuff from my last post? I hope I dont kill my ip but I am having the nozzles installed tomorrow. Let me know as soon as possible. Thanks
#40
You'll see a lot of people concerned with that here but you'll also see that several people have started to wonder about the idea that the pump has a number no matter what you do. I was starting to have an issue with my VP before I put my injectors in. When I fired it back up they seemed to excentuate the problem. But in the last 700 miles either my driving style has changed or the injectors are "breaking in" for lack of a better term and the pop pressure has dropped some.
Basically, try it and don't worry if the number is up it is up. Besides what your putting in should not put extra strain on the pump. Even with knowing my pump may be on its last leg I would throw a VA on if I had gotten one (instead of doing my holly/-8 lines).
Randy
Randy
#41
I would run the van aaken and buy some nozzles to put on the bodies you bought, then you can peddle the dd2's to recoup some of your dough, you asked about 120 hp edm's, well 100 horse is going to be BORING in very little time, you should go big once and be done with it...go jammer 4's....I wish I did.
#42
I already bought jammer 3's and they are being installed tomorrow hopefully. Got them for $200 new. I installed the va box tonight and it was nice to see the low end grunt. I think it is much better than the ez I tried. The truck doesnt smoke at all so it must be burning all the fuel. I only drove it about 20 minutes, but that was long enough to get rid of 2 old tires
#43
Well I found out today that I have the original lp and ip!! Needless to say I am starting to save for a new ip. Didnt get the nozzles put in today but I will get them in by the weekend. I cant stand seeing them just sitting on the kitchen counter.
king5335
11-07-2009 08:53 PM
91rangerturbo
02-18-2008 08:26 AM
Stroked-Z
31
12-06-2007 11:44 PM
PG4x4
05-04-2007 02:23 PM
sluggo42
12-27-2006 10:05 PM
