12 valve injector nozzles
Old 06-14-2006 | 11:52 PM
cnvrt2cummins's Avatar
I did a search and did not find a answer for my question, so here it is. Can I buy some bigger nozzles for my 215 inj. or not. I can not seem to understand why we can do it for everything else but I do not seem to see much about it on the 12 valve, it is always buy bigger inj. and I do not have that much money so I just want nozzles of course DV's would be nice as well.
Old 06-15-2006 | 12:09 AM
Fueling around's Avatar
They are available, but the injectors must still be bench tested for pop-off and correct spray angle.
Which pump size? A 215 or even a 180 hp pump will put out lots of ponies. How much does the wife need?
Old 06-15-2006 | 09:07 AM
Yeah, I know it will do real good with the fuel plate but I just kinda like to derive power from other sources instead of just the plate, I think so that way I always know if I need a little more umph I can have it within about 10 min for that is how long it takes me to slide my plate and be ready to roll, it is a lot easier on my suburban than on the dodge truck.
Old 06-15-2006 | 09:43 AM
signature600's Avatar
You can't buy nozzles because the complete injectors are cheap enough!! I won't run them, but a set of 3701's will take you to 600hp and run less than $400 a set, and on;y $500 for a set of PDR matched sticks!
To cheap to compete with
Chris
dodge_24
08-30-2009 09:50 PM
mtomac
32
12-20-2004 03:08 PM
jlells01
10-22-2004 07:29 PM
Zino
08-02-2004 07:10 AM
Amish hauler
02-22-2004 10:42 PM
