12 Valve Head Gasket???
I was wondering if you guys can help me out. I got a 12 valve at the machine shop right now. Got a brand new head and got the block decked. We have ARP studs but I don't want to o-ring the head. What is the best headgasket to run with headstuds shooting to hold 45psi of boost from a HTT 62/71/13SS?? Thanks...
.020 gasket.
Thet come in 3 different sizes. Stock, .010 over and .020 over.
Thing is, you need to get the same amount of metal shaved off the head so you dont drop your compression ratio. It will start and run good, it just makes it smokey when starting cold.
There are companies making MLS gaskets for our trucks, but going off of posts from this board, users have been having mixed results with them. It appears that the general trend is for them to leak coolant or oil between the steel layers.
Honestly if you are shooting for holding 45 lbs you should be just fine with studs, a stock Cummins gasket, and the occasional retorque. About 3 years ago when mine blew I talked to Schied about options and they told me their pulling truck used a stock Cummins gasket with stock bolts that were retorqued often (I assume they replaced them occasionally though).
As far as marine vs. standard gasket I don't know the difference between the two and the Cummins parts guy didn't either. Either one combined with studs will hold you safely at 45 psi.
ted_pulliam
07-16-2009 12:33 PM
rebel5422
04-11-2008 05:41 PM
wildchild97
09-25-2007 03:44 PM
Conn
12-29-2006 07:30 AM
