12 valve, 300 or 330's???
Old 10-25-2008 | 03:18 AM
thewished's Avatar
Which injector has anyone tryed. I do not want to here "go 370" I do not want 370's I want GOOD CLEAN CHEAP power. Anyone ran 300's or 330's?
Old 10-25-2008 | 07:04 AM
97 D-Tec's Avatar
well i know a bunch of people hate them and say their junk but my pensacola stage 2s work just fine
Old 10-25-2008 | 07:54 AM
logskidder's Avatar
You can send your stock nozzles out and have them fluid honed for a fair price. It can be a good route to go if you dont need a crazy amount of fuel.
Old 10-25-2008 | 08:00 PM
rattlerbob5.9's Avatar
I went with the 300's and have been very happy with them. The only problem with running them on a truck with the 160 pump is without changing the delivery valves to 181's is you may have a slight stutter from around 1000 to 1600 RPM under light throttle. You will have a good clean idle much better than the 370's
Old 10-26-2008 | 12:38 PM
thewished's Avatar
Who does this? I'm guessing my injectors are a little warn. I just rolled over 230,000 miles.
Old 11-02-2008 | 05:53 PM
Bersaglieri's Avatar
Yea, who does that? ^^
-Dustin-
Old 11-02-2008 | 06:11 PM
dieselman2300's Avatar
Just to let you know. Pensacola stage 2s are just Bosch Marine 300s. They are really ony a 40-50hp injector. Bosch marine 370 are a 90 hp injector.
The 300s are 4x.012 hole size.
They also arent the correct spray pattern. They are 155* pattern, our trucks have a 145* pattern.
The wrong pattern makes the truck smokey, hot, and will have idle haze.
I would check out http://www.neweradiesel.com/ diesel. Their injectors have the correct spray pattern and will run better in your truck. They also arent to much more money for the proper injector.
New Era is also a vendor on here.
Old 11-02-2008 | 06:31 PM
JohnX's Avatar
I have the 330's from Diesel Care and Performance Inc. No complaints on driveability or power. Quite a step up from stock power. Very noticeable gain off the line and down the road. BUT, they do haze a little more than I like. At $250 for the set, I couldn't really argue about a little haze though.
Old 11-02-2008 | 07:10 PM
logskidder's Avatar
Extrude hone in Pittsburgh Pa....Pm me if you want the contact info
CarcajouCummins
10-16-2006 03:16 PM
MrSuzuki
10-16-2005 06:22 PM
Dusty Ratcliff
10-06-2005 11:10 AM
Dshiftff
23
07-19-2005 12:39 PM
